# API traffic mirroring
API traffic mirroring allows you to mirror API traffic from your API collections to your external security information and event management (SIEM) provider for advanced analysis, including anomaly detection and PII monitoring. Enable this feature to send API request and response payloads, along with metadata, to your SIEM tool.
PRIVATE RELEASE
This feature is in private release. Private release features are available in production but only to selected customers. Contact your Customer Success Manager to enable this feature.
# Supported destinations
API traffic mirroring currently supports traffic mirroring to SALT Security (opens new window). Additional REST-based APIs may be supported in the future.
# Configure API traffic monitoring
Complete the following steps to configure API traffic mirroring with SALT Security:
Go to Platform > API Platform > Settings > Traffic mirroring.
Click Set up connection to open the Connect to HTTP dialog.
Set up your connection
If you already have an existing HTTP connection, select it from the list. Otherwise, create a new connection by entering the required details.
Enter a Connection name, such as SALT Security.
Select Cloud as the Connection type.
Select Header auth as the Authentication type.
Expand Header authorization and enter the following key-value pair:
- Key:
Authorization - Value:
Basic {SALT_API_TRAFFIC_COLLECTOR_TOKEN}
For example, if your SALT API traffic collector token is abc123XYZ, enter Basic abc123XYZ in the header Value field.
Enter header values
TOKEN MANAGEMENT
Retrieve the SALT API traffic collector token from your SALT Security instance or representative. Workato uses this token for authentication but does not manage or rotate it. You are responsible for ensuring its security and availability.
Optional. Use the Endpoint has case-sensitive headers? drop-down menu to specify whether your endpoint requires exact case matching for headers. Select Yes if exact matching is required, or No if case sensitivity is not required. The default is No.
Optional. Enter the Base URL for your mirroring service. This URL applies to all requests and cannot be overridden by recipes.
Click Connect to establish the connection.
Enter the endpoint for mirroring API request data in the Request destination URL field.
Specify your destination URLs
Enter the endpoint for mirroring API response data in the Response destination URL field.
SEPARATE ENDPOINTS
Workato mirrors API requests and responses separately to two distinct endpoints specified in the URL fields.
Verify that the provided endpoints are valid and accessible to your mirroring service.
Click Save to apply the configuration.
# Mirroring retry
If API traffic fails to mirror, Workato retries three times within a 10-minute period.
# Email notifications
Workato sends email notifications to your workspace's error notification recipients for the following events:
- Connection disconnected voluntarily
- Connection lost
- Traffic mirroring errors, such as a 401 Unauthorized error
Last updated: 10/14/2025, 4:38:57 PM
