# Cisco Webex Teams
Cisco Webex Teams (opens new window) is a collaboration platform that provides messaging, video meetings, and file sharing capabilities.
# API version
The Cisco Webex Teams connector uses Cisco Webex Teams API v1 (opens new window).
# How to connect to Cisco Webex Teams
Workato supports the following authentication methods for connecting to Cisco Webex Teams:
# OAuth 2.0
Complete the following steps to connect to Cisco Webex Teams using OAuth 2.0 authentication:
Click Create, then select Connection.
Search for and select Cisco Webex Teams in the New connection page.
Enter a name for the connection in the Connection name field.
Connect to Cisco Webex TeamsConnect to Cisco Webex Teams
Use the Location drop-down menu to select the project where you plan to store this connection.
Enter the email address associated with your Cisco Webex Teams account and click Sign in.
Click Accept. Workato requests the following permissions:
  • List the people in rooms that you're in
  • Read your company directory
  • List the titles of spaces that you are in
  • Post and delete messages on your behalf
  • Invite people to rooms on your behalf
  • Manage spaces on your behalf
  • Read the content of rooms that you're in
# Bot access token
You can use bot access token authentication to connect Workato to Cisco Webex Teams. This method requires two main steps:
  1. Create a bot in the Webex Developer Portal
  2. Complete the connection setup in Workato
# Create a bot in the Webex Developer Portal
Complete the following steps to create a bot in the Webex Developer Portal:
Sign in to the Webex Developer Portal (opens new window) and click Start Building Apps.
Click Create a Bot to open the New Bot (opens new window) page.
New bot pageNew bot page
Enter a name for your bot in the Bot name field. This is the bot name that appears in Webex and the Webex App Hub.
Enter a username for your bot in the Bot username field. Users use this username to add your bot to a space. This value cannot be changed later.
Upload a 512x512px JPEG or PNG file in the Icon field, or select a default option from Webex.
Provide an app description in 1024 characters or less in the App Hub Description field.
Click Add Bot to create your bot.
Click Copy Token to retrieve your bot access token. Store this value securely, as it is required to create your connection in Workato.
Copy the bot access tokenCopy the bot access token
# Complete the connection setup in Workato
Complete the following steps to configure the Cisco Webex Teams connection in Workato:
Use the Authentication type drop-down menu to select Bot access token.
Enter the bot access token in the Bot access token field. For detailed steps on how to obtain this value, see Create a bot in the Webex Developer Portal.
Refer to the Webex documentation for more information on Bots (opens new window).
Last updated: 3/10/2026, 8:58:20 PM
