# Google Calendar
Google Calendar (opens new window) is a cloud-based calendar application that enables scheduling, event tracking, reminders, and more.
You can use Workato to synchronize data with Google Calendar automatically as part of a workflow. For example, you can create events in your calendar when a meeting is scheduled in another platform or app. You can also retrieve details about calendar events and synchronize them with other tools, such as CRMs or project management platforms.
# API version
The Google Calendar connector uses the Google Calendar API v3 (opens new window).
# How to connect to Google Calendar
Workato supports the following types of connections to Google Calendar:
You can use a service account to authenticate without a personal user account. Workato recommends service account authentication for consistent use.
# OAuth 2.0 authentication
Complete the following steps to set up your Google Calendar connection using OAuth 2.0:
Click Create > Connection.
Search for and select Google Calendar as your connection on the New connection page.
Select the project where you plan to store the connection from the Location drop-down menu.
Select OAuth 2.0 as the Authentication type.
Click Sign in with Google, then sign in to your Google account. Ensure your Google account has sufficient permissions to manage the events and calendars you plan to use in Workato.
Click Sign in with Google.
# Service account authentication
A Google service account is a specialized Google account associated with a Google Cloud Project (GCP) that can run API requests on your behalf.
Service accounts provide the following benefits:
- Continuous operation: Service accounts ensure that operations continue even if individual user permissions change.
- Dedicated permissions: Service accounts can only access projects that you share with them.
- Dedicated API quotas: You can manage a service account's API quotas through GCP and request quota increases directly from Google.
Refer to the Google service account documentation (opens new window) to learn more about service accounts.
Service account authentication consists of the following actions:
# Minimum scopes for service account connections
The following scopes are required to connect to Google Calendar using a service account:
https://www.googleapis.com/auth/calendarhttps://www.googleapis.com/auth/calendar.eventshttps://www.googleapis.com/auth/admin.directory.resource.calendarhttps://www.googleapis.com/auth/taskshttps://www.googleapis.com/auth/userinfo.email
A 401 Unauthorized error may occur when the service account uses the Owner role or lacks required scopes. Assign the Editor role to the service account in the Google Cloud Console and confirm it includes all required scopes listed above. This ensures the service account can authenticate and access Google Calendar successfully.
Refer to the Google Calendar API scopes (opens new window) documentation for a complete list of supported scopes.
# Set up a Google service account
Complete the following steps to set up a Google service account:
Create a service account (opens new window) in your GCP project.
Go to IAM & Admin > Service accounts. Ensure your dashboard is scoped to the project that contains your service account.
Check the scope of your dashboard.
Click the Email of the service account you intend to use.
Copy the service account's Email and save it to configure your connection later.
Copy the account's Email.
Go to the KEYS tab.
Generate a private key (opens new window) and download it in JSON format. You can only download the key once.
Open the JSON file, then copy the entire private key from -----BEGIN PRIVATE KEY----- to -----END PRIVATE KEY-----\n (inclusive) and save it to configure your connection later.
# Enable the Google Calendar API
You must enable the Google Calendar API before you return to Workato to finish setting up your connection.
Sign in to Google's API library (opens new window).
Search for and select the Google Calendar API.
Click Enable to enable the API.
# Complete setup in Workato
Complete the following steps in Workato to set up your Google Calendar connection using a service account:
Select Service account as the Authentication type.
Enter your service account's Private key.
Provide the User email of the account you plan to impersonate.
User impersonation lets the service account act on behalf of a designated user, accessing and managing events in their Google Calendar. Impersonating a user ensures data accuracy and enforces the permissions and access controls set for that user in Google Calendar. Refer to Google's Service account impersonation (opens new window) guide for more information.
Click Sign in with Google to complete the setup.
Configure Google Calendar service account connection
Last updated: 3/5/2026, 12:08:37 AM
