Microsoft Graph API
Microsoft Graph API is a powerful unified endpoint that allows organizations to access and interact with Microsoft 365 services and other Microsoft cloud-based resources. It enables developers to integrate and automate various application actions, such as managing users, groups, mail, calendars, tasks, and security insights.
With Microsoft Graph API, organizations can enhance security, streamline user management, and enable seamless single sign-on experiences across different applications. It provides access to:
  • External resources, such as Microsoft 365, the Azure portal, and thousands of other SaaS applications.
  • Internal resources, such as apps on your corporate network, intranet, and any cloud apps developed by your organization.
Install Microsoft Graph API from the community library
Complete the following steps to install the Microsoft Graph API connector from the community library:
Click installClick Install
Connection setup
The Microsoft Graph API connector supports the following authentication types:
MICROSOFT MFA ENFORCEMENT
Authorization code grant authentication (OAuth 2.0)
Authorization code grant authentication signs in as a specific user and uses Delegated permissions.
This authentication type requires the following values:
  • Client ID
  • Client secret
  • Tenant ID (required for single tenant)
Minimum and default scopes
When no scopes are provided in the Scopes input field, the Microsoft Graph API connector requests the following scopes for authorization code grant connections by default. These scopes are necessary to use all of the connector's triggers and actions. You must assign these permissions to the Workato app as Delegated permissions in the Azure portal.
  • offline_access
  • openid
  • profile
  • User.Read
  • User.Read.All
  • User.ReadBasic.All
  • User.ReadWrite
  • User.ReadWrite.All
  • Directory.Read.All
  • Directory.ReadWrite.All
  • Files.ReadWrite.All
  • Mail.ReadBasic
  • Mail.Read
  • Mail.ReadWrite
  • Mail.Send
  • MailboxFolder.Read
  • MailboxFolder.ReadWrite
  • Calendars.Read
  • Calendars.ReadBasic
  • Calendars.ReadWrite
  • OnlineMeetings.Read
  • OnlineMeetings.ReadWrite
  • OnlineMeetingArtifact.Read.All
  • OnlineMeetingTranscript.Read.All
  • OnlineMeetingRecording.Read.All
The following scopes are not requested by default. Add them through the Scopes input field when you create a connection if your use case requires them:
  • DeviceManagementManagedDevices.Read.All
  • DeviceManagementManagedDevices.ReadWrite.All
The following minimum scopes are required to establish a connection to Microsoft Graph API using authorization code grant authentication:
  • User.Read
  • offline_access
Microsoft Graph API setup for authorization code grant authentication
Complete the following steps to set up the Microsoft Graph API connector for authorization code grant authentication:
Register the Workato app in the Azure portal
View register the Workato app in the Azure portal steps
Sign in to the Azure portal.
html
Select Register.
Assign permissions to your app
View assign permissions to your app steps
Complete the following steps to assign permissions to your app:
Go to your newly registered app and select Manage > API permissions.
Click + Add a permission and select Microsoft Graph.
Select Delegated permissions as the permission type, since your application requires a user to sign in.
Add permissionsAdd permissions
Add the required permissions. Refer to Minimum and default scopes for the scopes to assign.
Click Add permissions.
Admin consent is required for specific permissions. Refer to Connect Microsoft Entra ID to the Microsoft Graph API connector to learn more.
Generate a client secret
View generate a client secret steps
Click + New client secret.
Click Add.
Copy and save the client secret valueCopy and save the client secret value
Obtain the Application (client) ID and Directory (tenant) ID from the Azure portal
View obtain the Application (client) ID and Directory (tenant) ID from the Azure portal steps
Complete the following steps to obtain the Application (client) ID and Directory (tenant) ID from the Azure portal:
App detailsApp details
Copy and save the Application (client) ID and Directory (tenant) ID for use in Workato.
Connect to Microsoft Graph API with authorization code grant authentication
Complete the following steps to establish an authorization code grant connection to Microsoft Graph API in Workato:
Search for Microsoft Graph API and select it as your app.
Connect to Microsoft Graph API with authorization code grant authenticationConnect to Microsoft Graph API with authorization code grant authentication
Enter the Application (client) ID from the Azure portal in the Client ID field.
Enter your client secret in the Client secret field.
Select Authorization code grant from the Authentication type drop-down menu.
Select an option from the Account type drop-down menu. Options include Single tenant, Multitenant, and Active directory multitenant.
Enter the Directory (tenant) ID in the Tenant ID field. This field is required if you select Single tenant as the Account type.
Optional. Select the scopes you need from the Scope drop-down menu. By default, the connector requests the scopes listed in Minimum and default scopes, which cover all of its triggers and actions.
Client credentials-based authentication (OAuth 2.0)
Client credentials-based authentication connects as the application and uses Application permissions.
  • Client ID
  • Client secret
  • Tenant ID
Minimum and recommended scopes
For client credentials connections, the connector uses the Application permissions consented for the app in the Azure portal. We recommend assigning the following permissions to support common operations across the connector's triggers and actions. Some operations may require additional Application permissions.
  • User.Read.All
  • Mail.Read
  • Mail.ReadWrite
  • Mail.Send
The following minimum scope is required to establish a connection to Microsoft Graph API using client credentials authentication:
  • User.Read.All
Microsoft Graph API setup for client credentials-based authentication
Complete the following steps to set up the Microsoft Graph API connector for client credentials-based authentication:
html
Select Register.
Select Application permissions as the permission type, since your application doesn't require a user to sign in.
Add the required permissions. Refer to Minimum and recommended scopes for the scopes to assign.
Click Add.
Connect to Microsoft Graph API with client credentials-based authentication
Complete the following steps to establish a client credentials-based connection to Microsoft Graph API in Workato:
Connect to Microsoft Graph API with client credentials-based authenticationConnect to Microsoft Graph API with client credentials-based authentication
Select Client credentials from the Authentication type drop-down menu.
View connect Microsoft Entra ID to the Microsoft Graph API connector steps
To connect to the Microsoft Graph API connector using a Microsoft Entra ID account, ensure that all the consent requests are granted by admins.
Complete the following steps to grant admin consent using an admin account:
Sign in to your Azure portal and navigate to Enterprise Applications > Activity > Admin consent requests.
Approve the necessary consent requests.
