XML tools by Workato ​
XML tools by Workato provides actions to extract values, transform XML structures, and process attributes, enabling seamless recipe integration.
XML (eXtensible Markup Language) is a widely used format for storing and exchanging data, especially in APIs. Workato recipes typically expose XML data as input fields and datapills, but some workflows require direct interaction with XML content.
How XML tools by Workato works ​
XML tools by Workato provides the following actions to process XML data:
Setup ​
This connector doesn't require authentication or a connection setup.
Handle large XML documents ​
XML tools by Workato actions support XML payloads up to 10 MB at runtime by default. This applies to actions that process XML documents, such as parsing, generating, transforming, and validating XML.
The Parse XML document action supports payloads up to 200 MB when you set Enable streaming? to Yes.
Enable streaming ​
The Enable streaming? field controls how the Parse XML document action handles XML payloads at runtime.
  • No (default)
  • The action supports XML payloads up to 10 MB and returns the parsed output as datapills. Results return faster, which makes this the right choice for smaller payloads.
  • Yes
  • The action supports XML payloads up to 200 MB. Workato writes the parsed JSON to file storage and returns it as a reference. Streamed processing is optimized for throughput.
Set Enable streaming? to Yes when you anticipate large XML payloads.
Quotas ​
The XML tools by Workato connector has the following quotas:
File size quotas ​
DescriptionQuota
XML tools by Workato actions, default payload quota10 MB
Parse XML document action, with streaming enabled200 MB
Action-specific quotas ​
DescriptionQuota
Maximum number of fields for the Generate XML document from XSD action5,000 fields
Schema building quotas ​
DescriptionQuota
Maximum nesting depth of a schema built from XSD or sample XML300
Maximum number of properties, objects, and arrays in a schema built from XSD or sample XML15,000
Maximum number of child properties in a single object of an XML-derived schema5,000
Maximum time to build one XML schema, per request or response10 seconds
