Custom interface API walkthrough ​
Headless API endpoints are designed to be called in sequence. Each request in a conversation lifecycle depends on identifiers returned by a previous request. This guide demonstrates how to chain requests together to manage a complete conversation, handle interruptions, and respond to skill confirmation and runtime connection events.
Conversation lifecycle overview ​
A complete genie conversation follows this sequence:
  • Create a conversation to obtain a conversation_id.
  • Send a message using the conversation_id and stream the genie's response.
  • Handle Server-Sent Events (SSE) emitted during the stream, including skill confirmations and runtime connection requests.
  • Retrieve messages or events if the stream disconnects before it closes.
Every subsequent request in a session depends on the conversation_id returned in the initial request. You must retain this value for the duration of the session.
Complete request chain ​
The following table summarizes the full sequence of API calls for a conversation session, including the identifier each request produces and where it's used next:
StepRequestProducesUsed by
Create a conversationPOST
/conversations
conversation
_id
All
subsequent requests
Send a message and stream the responsePOST /messagesgenie_run_idReconnect
endpoint
Attach a file (optional)POST /uploadfile_idPOST /messages
SSE: Skill confirmation requiredPOST
/skill_approval
/:call_id
ResolutionGenie resumes
SSE: Runtime connection authentication requiredPOST
/runtime_connection
/:runtime_connection
_attempt_id/link
Auth urlPresented to user
Reconnect to the streamGET
/genie-runs/
:genie_run_id
Resumed
SSE
stream
Fetch missed events manuallyGET
/conversations
/events
Missed
events
Retrieve conversation historyGET /messagesMessage
history
Display
or audit
How to chain Headless API requests ​
Complete the following steps to chain Headless API requests:
Create a conversation ​
You must create a conversation before you can send a message. This request returns the conversation_id you pass to every subsequent request in the session.
Run the following request to create a conversation and obtain a conversation_id:
bash
POST /api/v1/genies/:genie_handle/chat/conversations
Send a message and stream the response ​
Send a message using the conversation_id and stream the response. Set stream to true to receive a real-time SSE stream as the genie processes the request. The genie_run_id returned in the response is required if you need to reconnect after a disconnection.
bash
POST /api/v1/genies/:genie_handle/chat/conversations/:conversation_id/messages
Attach a file to a message ​
Upload the file before sending the message if you plan to include an attachment. Pass the file_id returned by the upload in the file_id parameter of the send message request.
bash
POST /api/v1/genies/:genie_handle/chat/conversations/:conversation_id/upload
Handle SSE events
Handle SSE events ​
Your application must listen for and respond to events while the stream is open. Some events require immediate action before the genie can continue. Other events are informational.
Skill confirmation required ​
When the genie emits a skill.confirmation_required event, it pauses execution and waits for your application to approve or reject the skill call. The event payload includes a call_id. Use the call_id to approve or reject the skill:
bash
POST /api/v1/genies/:genie_handle/chat/conversations/:conversation_id/skill_approval/:call_id
Runtime connection authentication required ​
When the genie emits a runtime_connection.auth_required event, it requires the user to authenticate a connection before the skill can execute. The event payload includes a runtime_connection_attempt_id and an auth_link.
Use the runtime_connection_attempt_id to request an authentication link to present to the user:
bash
POST /api/v1/genies/:genie_handle/chat/runtime_connection/:runtime_connection_attempt_id/link
The response returns a status field. When status is auth_required, present the auth_link.url to the user to complete authentication. Poll this endpoint until status is authorized, which indicates the connection is complete and the genie has resumed processing; then read the resumed reply from message history.
Use the following command to cancel the connection request:
bash
POST /api/v1/genies/:genie_handle/chat/runtime_connection/:runtime_connection_attempt_id/reject
Recover from a disconnection
Recover from a disconnection ​
Use one of the following recovery methods if the SSE stream disconnects before the genie emits processing.finished:
Reconnect to the stream ​
Reopen the SSE stream for the genie run using the genie_run_id. Pass the ID of the last successfully received event in the Last-Event-ID header to replay only the events you missed:
bash
GET /api/v1/genies/:genie_handle/chat/conversations/:conversation_id/genie-runs/:genie_run_id
Fetch missed events manually ​
Use the get events endpoint as a fallback if you can't reconnect to the stream. Events are available for 24 hours. Pass the since_created_at parameter to retrieve only events that occurred after your last successfully received event.
bash
GET /api/v1/genies/:genie_handle/chat/conversations/events?conversation_id=:conversation_id&since_created_at=:since_created_at
Retrieve conversation history ​
You can retrieve the full message history for the conversation using the conversation_id after a conversation closes. Use the following endpoint to display prior messages when a user returns to an existing conversation, or to fetch the genie's final response if your stream closed before the agent.message event was received:
bash
GET /api/v1/genies/:genie_handle/chat/conversations/:conversation_id/messages
