Build a custom chat UI
This guide demonstrates how to build an end-to-end custom chat interface on the Headless API. Building a UI requires calling endpoints, a backend that holds credentials safely, and a frontend that turns the Server-Sent Events (SSE) stream into a live, trustworthy conversation.
Use this guide alongside the Headless API reference for endpoint details and the Custom interface API walkthrough for the request sequence.
Build overview
Use this guide to build a backend that holds credentials and proxies requests and a browser frontend that streams a genie conversation into live cards and message bubbles. Build in the following order:
- Step 1: Stand up a backend between the browser and the API.
- Step 2: Open the stream and run a render loop that dispatches each event.
- Steps 3–6: Handle each event type, such as skill activity, approvals, connection requests, and messages.
- Step 7: Track state and recover after reloads and dropped streams.
Each step builds on the previous one. The render loop in step 2 is the spine: every later step is a handler the loop dispatches into.
Step 1: Put a backend between the browser and the API
Don't call the Headless API directly from the browser. Stand up a small same-origin backend that the browser talks to, and let the backend talk to Workato. This protects credentials and avoids cross-origin (CORS) problems.
Credentials belong to a specific genie client. Use the API key or OAuth client_id of the client for the interface you're building if your genie has multiple clients.
- Don't expose the Developer API token (
wrkaus-…) in client-side code. It's a builder secret used only for provisioning. The browser should only see the public OAuthclient_idand the end user's own OAuth access token. - Relay the OAuth token exchange through the backend. The browser runs the PKCE flow and receives the authorization
code, then your backend exchanges thecode(and later therefresh_token) atid.workato.com/oauth/token. This keeps token handling server-side and avoids cross-origin requests to the identity host. Theredirect_urimust match the redirect URL you registered for the client. You can update a client's redirect URL after you create it. Refer to Genie clients for more information. - For API-key integrations, inject auth on the backend. The backend holds the API key and adds the
AuthorizationandX-IDP-User-Idheaders to each runtime request, then proxies the SSE stream back to the browser.
CHOOSE OAUTH FOR USER-FACING UIS
Use OAuth 2.0 (PKCE) for any UI that real users sign in to. API-key auth uses a single static key per client for all callers. Use this only for trusted server-to-server backends, not browsers. Refer to Authentication for more information.
When the user sends a message, your backend calls Send a message with stream: true and proxies the SSE response to the browser. The frontend reads that stream and dispatches each event to a handler. This loop is the core of the UI, and everything else is a handler it calls.
Read the stream line by line, track the current event: type, parse each data: line as JSON, and dispatch on the type. A blank line separates events. For example:
// `response` is the proxied SSE stream from your backend.
let currentEvent = null;
for await (const line of readLines(response.body)) {
if (line.startsWith("event:")) {
currentEvent = line.slice(6).trim();
} else if (line.startsWith("data:")) {
dispatch(currentEvent, JSON.parse(line.slice(5).trim()));
function dispatch(type, data) {
switch (type) {
case "processing.started": showTypingIndicator(); break;
case "skill.running":
case "skill.completed":
case "skill.failed": updateSkillCard(data); break;
case "skill.confirmation_required": renderApprovalCard(data); break;
case "runtime_connection.auth_required": renderConnectionCard(data); break;
case "agent.message": renderMessage(data); break;
case "processing.finished": endTurn(); break;
default: break; // ignore system.ping and unknown types
}The following table maps each event to what your UI does with it. The steps after it implement each handler.
| Event | Carries | What your UI does |
processing.started | Shows a typing indicator | |
skill.running / skill.completed / skill.failed | skill_name, skill_id | Creates or updates a skill card, keyed by skill_name |
skill.confirmation_required | call_id, skill_name, skill_parameters | Shows an approval card with parameters and Approve and Reject buttons |
runtime_connection.auth_required | runtime_connection_attempt_id, auth_link | Open auth_link.url, then poll for completion (see Step 5) |
agent.message | message_id, message | Renders a chat bubble. De-duplicate by message_id and render markdown |
processing.finished | Ends the turn and removes the typing indicator | |
system.ping | Ignores. This is a keep-alive sent during long or paused turns |
IGNORE UNKNOWN EVENT TYPES
Treat any event type you don't recognize as a no-op, as the default case above does. This keeps your UI forward-compatible and absorbs keep-alive events like system.ping.
Step 3: Handle skill events
For each skill the genie runs, render a single card that updates in place across its lifecycle. For example, running to completed, or failed, rather than appending a new item per event.
- Key cards by
skill_name, notcall_id.skill.runningandskill.completedtypically don't carry acall_id— onlyskill_nameandskill_id(in the formrecipe:<numeric_id>). Onlyskill.confirmation_requiredis guaranteed to includecall_id. - Handle parallel tool calls: When the genie runs several skills at once, you receive a single
skill.runningbut askill.completedfor each skill. If askill.completedorskill.failedarrives for askill_namewith no existing card, create the card so every call is represented. Don't assume arunningevent precedes a terminal event. Some runtime versions also emitskill.stoppedin place ofskill.completed, which you should treat as a terminal success. - Don't render results from
skill.completed: This event doesn't include a structuredresult. The genie feeds the result to the model internally and reflects it in the nextagent.message. Show the card transitioning tocompletedfor feedback, and let the agent message carry the data. If you need the structured output, for example, to draw a chart, fetch the recipe's job output server-side through the Developer API. Refer to Correlate skill IDs for more information.
Step 4: Handle approvals
When a skill needs confirmation, the genie emits skill.confirmation_required and pauses the turn. Render the skill card in an awaiting state and expand it:
- Show the resolved parameters from the event's
skill_parametersfield as a key/value list, so the user can verify what the genie is about to submit. - Add Approve and Reject buttons with real visual weight, not small inline icons.
- Resolve the request with Approve or reject a skill, passing the event's
call_id. The same stream resumes after you post a resolution. - Render the approval card once and update it in place. If your UI polls for events rather than holding the SSE stream open, don't rebuild the turn on every poll. Most polls during a pause return only heartbeats, and continuously recreating the card can drop clicks on the Approve button. Skip re-rendering when the content is unchanged, or render the card into its own node that the event-list re-render doesn't overwrite.
When the user rejects, the genie's next agent.message can quote the rejection_reason verbatim. Send a generic reason (or none) if you don't want the user's words echoed back into the conversation.
Step 5: Handle connection requests
The genie emits runtime_connection.auth_required, then pauses the turn, when a skill requires the end user's own credentials for an upstream system (Verified User Access). The event carries both a runtime_connection_attempt_id and an auth_link with the authentication URL.
- Render a card in an
awaitingstate with a button that opensauth_link.url, for exampleConnect to your account. Apply the same render-once, update-in-place rule as approval cards so the button stays clickable. If the link has expired, fetch a fresh one with Get a runtime connection link using theruntime_connection_attempt_id. - Detect when the connection completes by polling Get a runtime connection link until
statusisauthorized, or by polling Get a conversation untilstateleavesskill_processing. - The open SSE stream does not deliver the resumed turn after the user authenticates. It emits only
system.ping, then asystem.stream_interrupted. Once the connection completes, read the resumed reply from message history (de-duplicate bymessage_id); see step 7.
Because the user completes the login out-of-band and often takes longer than the stream's idle window, treat the dropped stream as expected here — recover from persisted state rather than assuming the turn failed.
Step 6: Render agent messages
Render agent.message events as chat bubbles, with two things to handle:
- De-duplicate by
message_id: The same message can arrive on both the SSE stream and the message history endpoint when you reconnect. Keep a set of seenmessage_idvalues. - Render markdown: Message text is typically markdown, such as bold, lists, links, and occasional code. Render it with a markdown library or a small inline renderer. If your bubble style uses
white-space: pre-wrap, setwhite-space: normalon the markdown container so block elements lay out correctly.
Anchor the typing indicator to the bottom of the message list: re-anchor it below any skill cards you append, so the user sees their message, then live skill activity, then the reply replacing the indicator.
Show the conversation's overall state (for example, a status pill) by deriving it from the latest event, falling back to Get a conversation when you reconnect. The conversation state is one of idle, ai_running, skill_processing, or awaiting_approval. A runtime-connection pause keeps state at skill_processing; awaiting_approval indicates a skill.confirmation_required pause.
Rebuild the conversation from persisted data on a reload or dropped stream rather than assuming the live stream is the only source. Complete the following steps to rebuild the conversation:
Fetch the message history and the persisted events from Get events.
Merge and order the two lists by created_at (events also carry a per-run seq_num).
De-duplicate messages by message_id, then replay the merged list through the same handlers from steps 3–6.
All event types, including skill.* and processing.*, persist for 24 hours, so you can reconstruct a full timeline from Get events. The one exception is a turn resumed after a runtime-connection (Verified User Access) pause: the resumed events aren't in Get events, so recover that reply from message history instead. Refer to Rebuild a conversation timeline.
Putting it together
A complete custom chat UI has four components in the following order:
- A backend that holds credentials and proxies requests
- A render loop that dispatches the SSE stream
- A handler per event type that drives cards and bubbles
- A recovery that rebuilds from persisted data.
You can send a message, confirm a skill card appears and an agent.message renders, approve a skill that requires confirmation, then reload mid-turn and confirm the timeline rebuilds to ensure your build works as expected.
Three invariants are worth restating, because each is a place a naive build breaks:
- Key skill cards by
skill_name, because terminal skill events often omitcall_id. - Treat
processing.finishedas the end of the turn, and ignore unknown event types. - On reload, rebuild from Get events and message history. Don't treat the live stream as the only source.
Correlate skill IDs across surfaces
The same skill is identified differently depending on where you look, which matters when you correlate a live tool call back to a skill or job record, for example, to fetch a skill's structured output server-side:
| Surface | Skill identifier |
| Headless SSE events | skill_id as recipe:<numeric_id> |
Developer API skills (/api/agentic/skills) | skl-… handle, with the numeric recipe ID as provider_id |
Developer API recipes (/api/recipes/:id) | numeric recipe ID |
Match by skill_name where you can — it's the most reliable key across surfaces. To map an SSE skill_id to a skill record, strip the recipe: prefix and match the numeric ID against the skill's provider_id.
