Workato Genie connector
The Workato Genie connector provides actions to interact with genies and their supporting systems from within a recipe.
CONNECTOR ACCESS
The Workato Genie connector is available to customers on plans with Agent Studio enabled.
Connection setup
The Workato Genie connector is a built-in connector. It doesn't require authentication or connection setup.
Actions
The Workato Genie connector supports the following recipe actions:
Deprecated features
The following Workato Genie connector features are deprecated. These features continue to function in existing recipes but don't receive new enhancements:
  • Start workflow trigger: The trigger used to define skills. Replaced by the Workato Skill connector, which provides the same functionality without requiring access to genies. You can't add this trigger to new skills.
  • Return response action: The action used to return a result from a skill. Replaced by the Return response action in the Workato Skill connector.
Refer to Transition from the Workato Genie connector for migration steps.
