# Clone a recipe from the community library
You can clone a recipe from the community library into a project.
REQUIRED PERMISSIONS
Cloning recipes from the community library requires recipe creation permissions. If you don't have the required permissions, contact your workspace admin to help you clone the recipe into your workspace.
Complete the following steps to clone a recipe from the community library (opens new window):
Select the community recipe you plan to use.
Select a community recipeSelect a community recipe
Verify that the recipe fits your use case and assess the quality of the recipe's workflow logic.
Click Use this recipe.
Use this recipeClick Use this recipe
Select the project where you plan to save the recipe, or click + New project to create a new project.
Select where to save the recipeSelect where to save the recipe
Click Copy and save to save a copy of the recipe.
Copy and saveClick Copy and save
Click Customize recipe to open the recipe editor and begin customizing your recipe.
Customize recipeClick Customize recipe
Last updated: 10/22/2025, 9:03:09 PM
