Active Directory - Search entries action (Batch)
The Search entries batch action retrieves a list of Active Directory entries matching the criteria you specify and processes them in batches.
Input
| Sample entry DN | Specify the distinguished name (DN) of a reference entry. The action uses this entry’s attributes as a template to define sub-fields in the Search entries by field and retrieve values from matching entries. |
| Limit | Enter the maximum number of entries you plan to retrieve for each action. The maximum is 1,000 entries. |
| Batch size | Optional. Enter the maximum number of entries to return in each batch. Defaults to 1000. |
| Batch cookie | Optional. Enter the Batch cookie from a previous iteration of this action to retrieve the next batch of results. Leave this field blank to retrieve the first batch. |
| Search entries by | Enter values for each attribute you plan to filter by. Only entries that match all the provided values are processed. This field includes sub-fields for each attribute of the reference entry. |
| Advanced search filter | Enter LDAP filters to define search conditions. For example, enter (ou=Dev)(objectClass=Person) to retrieve only Person entries from the Dev organization unit. |
Output
| Batch cookie | A pagination token for the next batch of results. |
| Entries | Returns the entries that match your search criteria, including values for each attribute defined by the sample entry. |
