Allure TestOps
Allure TestOps is a test management platform by Qameta Software that provides end-to-end test management capabilities, including test case management, test plan creation, launch execution, and result tracking. The Allure TestOps connector enables you to create, search, update, and delete projects, test cases, test plans, launches, and test results, and to retrieve and search custom fields and their values.
Install Allure TestOps from the community library
Complete the following steps to install the Allure TestOps connector from the community library:
Search for community connectors in the recipe editor
Click Install
Release the connector
The Confirm release dialog
Connection setup
The Allure TestOps connector uses Bearer token authentication.
Allure TestOps setup
Complete the following steps to set up an instance URL and an API token to establish a connection to Allure TestOps in Workato:
Sign in to your Allure TestOps account.
Click the profile icon to open your profile settings.
Go to API Tokens and click Generate a token.
Copy and securely store the token for use in Workato.
Connect to Allure TestOps using Bearer token authentication
Complete the following steps to connect to Allure TestOps in Workato:
Search for and select Allure TestOps as your connection on the New connection page.
Create an Allure TestOps connection.
Enter your full Allure TestOps URL in the Instance URL field, for example https://yourcompany.testops.cloud.
Enter the API token you generated in Allure TestOps.
