Allure TestOps - Create record action
The Create record action creates a new record in Allure TestOps.
Input
Input fields load dynamically based on the object you select. The following input field is common to all objects. Refer to the Allure TestOps documentation for a complete list of input fields.
Input fieldDescription
ObjectSelect the object type to create. Options include Project, Test case, Test plan, Launch, and Test result.
Output
Output fields load dynamically based on the object you select. Refer to the Allure TestOps documentation for a complete list of output fields.
