Allure TestOps - Delete record action
The Delete record action deletes a record by its ID.
Input
Input fields load dynamically based on the object you select. The following input field is common to all objects. Refer to the Allure TestOps documentation for a complete list of input fields.
Input fieldDescription
ObjectSelect the object type to delete. Options include Project, Test case, Test plan, Launch, and Test result.
Output
FieldDescription
SuccessWhether the record was deleted successfully.
