Allure TestOps - Search records action
The Search records action searches for records matching criteria.
Input
Input fields load dynamically based on the object you select. The following input field is common to all objects. Refer to the Allure TestOps documentation for a complete list of input fields.
| Object | Select the object type to search. Options include Project, Test case, Test plan, Launch, Test result, Custom field, and Custom field value. |
Output
Output fields load dynamically based on the object you select. Refer to the Allure TestOps documentation for a complete list of output fields.
