Allure TestOps - Get record action
The Get record action retrieves details of a record by its ID.
Input
Input fields load dynamically based on the object you select. The following input field is common to all objects. Refer to the Allure TestOps documentation for a complete list of input fields.
Input fieldDescription
ObjectSelect the object type to retrieve. Options include Project, Test case, Test plan, Launch, Test result, Custom field, and Custom field value.
Output
Output fields load dynamically based on the object you select. Refer to the Allure TestOps documentation for a complete list of output fields.
