Azure DevOps - New work item (batch) trigger
The New work item (batch) trigger monitors Azure DevOps new work items.
Input
Input fieldDescription
Batch sizeEnter the number of entries to process in each batch. Defaults to 100 if not specified. Maximum batch size is 200.
When first started, this recipe should pick up events fromSpecify the date and time from which the recipe picks up trigger events. Defaults to tasks created or updated 1 hour ago. You can't change this value after running or testing the recipe. Refer to Triggers to learn more about this input field.
ProjectSelect the project to monitor for new work items.
Output
Output fieldDescription
Work itemsInformation about the new work items, including Work item ID, Work item URL, and Revision number.
