Azure DevOps - New/Updated work item (batch) trigger
The New/Updated work item (batch) trigger monitors Azure DevOps for new or updated work items.
Input
Input fieldDescription
Batch sizeEnter the batch size. Default is 100. Maximum is 200.
When first started, this recipe should pick up events fromSet the date and time to start picking up trigger events. This enables your recipe to capture past events. Refer to Triggers to learn more about this input field.
ProjectSelect the project to monitor.
Output
Output fieldDescription
Work itemsInformation about the new or updated work item, including Work item ID, Work item URL, Revision number, and Fields.
