Azure DevOps - Update record action
The Update record action updates a record in Azure DevOps.
Input
| Object | Select the object to update. |
| Project | Select the project where you plan to update a record. |
| ID | Enter the ID of the record, such as a Work item ID for a work item object. |
| Type | Select the work item type. |
Output
This action has a large number of output fields. Refer to the Azure DevOps documentation for a complete list of output fields.
