Azure DevOps - Search records action
The Search records action searches for records in Azure DevOps.
Input
Input fields are dynamically generated based on the object you select.
Input fieldDescription
ObjectSelect the type of object to search for in Azure DevOps records. Object types include project, board, board_column, build, build_log, run, and work_item.
Output
Output fields are dynamically generated based on the object you select. Refer to the Azure DevOps documentation for a complete list of output fields.
