Azure OpenAI
Azure OpenAI is a collaboration between Microsoft Azure and OpenAI, an artificial intelligence research organization. Azure OpenAI is a cloud-based platform that enables users to build and deploy AI models. These models allow you to edit text, generate images, and perform classification. You can fine-tune and create models that are exposed internally using Azure OpenAI.
API version
The Azure OpenAI connector uses the Azure OpenAI Service REST API.
How to connect to Azure OpenAI
Workato supports the following types of connections to Azure OpenAI:
MICROSOFT MFA ENFORCEMENT
OAuth 2.0 authentication
OAuth 2.0 authentication consists of the following steps:
Prerequisites
You must complete the following prerequisites to establish an OAuth 2.0 connection to Azure OpenAI:
- Refer to the Azure OAuth 2.0 authorization documentation to generate a client ID and secret using an identity provider, such as Microsoft Entra ID.
- Refer to the Azure Delegate an Azure DNS subdomain documentation to delegate a subdomain in the Azure portal.
Complete setup in Workato
Complete the following steps to establish an OAuth 2.0 connection to Azure OpenAI:
Search for and select Azure OpenAI as your connection on the New connection page.
Azure OpenAI OAuth 2.0 connection
Enter the Client ID and Client secret for your Azure application.
Enter your organization's Sub domain.
API key authentication
API key authentication consists of the following steps:
Prerequisites
You must complete the following prerequisites to establish an API key connection to Azure OpenAI:
- Refer to the Azure OpenAI Authentication documentation to generate an API key. Workato recommends that you store the API key safely, as it's only displayed once.
Complete the following steps to establish an API key connection to Azure OpenAI:
Azure OpenAI API key connection
Use the Authentication type drop-down menu to select API key.
Enter the API key.
Supported actions
Azure OpenAI supports the following actions:
