Canva Connect - Create design autofill action
The Create design autofill action autofills a brand template with data you provide and returns the created design once the job finishes in Canva Connect. The action waits for the autofill job to complete and times out after 30 minutes. This action requires the brandtemplate:content:read, design:content:write, and design:meta:read scopes, and is only available on Canva Enterprise plans.
Input
Input fields dynamically generate based on the brand template you select. The following fields are common to all brand templates. Refer to the Canva Connect documentation for a complete list of input fields.
| Brand template | Enter or select the brand template to autofill. |
| Title | Enter the title to use for the autofilled design. Maximum length is 255 characters. The design uses the brand template's title if left blank. |
| Enter the email to autofill the brand template with. | |
| Name | Enter the name to autofill the brand template with. |
Output
Output fields dynamically generate based on the brand template you select. The following fields are common to all brand templates. Refer to the Canva Connect documentation for a complete list of input fields.
| Type | The autofill result type. |
| Design ID | The unique ID of the created design. |
| Title | The title of the design. |
| URL | The URL of the created design. |
| Thumbnail | The width, height, and URL of the design's thumbnail image. |
| URLs | The edit URL and view URL for the design. |
| Created at | The date and time the design was created. |
| Updated at | The date and time the design was last updated. |
| Page count | The number of pages in the design. |
