Canva Connect - Create design autofill job action
The Create design autofill job action starts an asynchronous job that autofills a brand template with data and returns the job ID immediately in Canva Connect, instead of waiting for the job to finish. Use the Get record details by ID action with the Design autofill job object to poll the job for its status and resulting design.
This action requires the brandtemplate:content:read, design:content:write, and design:meta:read scopes, and is only available on Canva Enterprise plans.
Input
Input fieldDescription
Brand template IDEnter the ID of the brand template you plan to autofill.
TitleEnter the title you plan to use for the autofilled design. The design uses the brand template's title if left blank.
Data valuesEnter the data you plan to autofill into the brand template. Each entry has a key, a type, and the value to insert.
Output
Output fieldDescription
Job IDThe ID of the autofill job.
StatusThe status of the autofill job.
