Canva Connect - Search records action
The Search records action retrieves a list of records of a selected object type from Canva Connect that match your search criteria. Supported objects include folder items, designs, and brand templates. Requires a Canva Pro, Teams, or Enterprise plan.
Input
Input fields dynamically generate based on the object you select. The following field is common to all objects. Refer to the Canva Connect documentation for a complete list of input fields.
| Object | Select the Canva Connect object you plan to search. |
Output
Output fields dynamically generate based on the object you select. Refer to the Canva Connect documentation for a complete list of output fields.
