Canva Connect - Update record action
The Update record action updates a record in Canva Connect. Supported objects are folders, folder items, and assets.
Input
Input fields dynamically generate based on the object you select. The following field is common to all objects. Refer to the Canva Connect documentation for a complete list of input fields.
| Object | Select the Canva Connect object you plan to update. |
Output
Output fields dynamically generate based on the object you select. Refer to the Canva Connect documentation for a complete list of output fields.
