Cornerstone HR - Get record details by ID action
The Get record details by ID action retrieves the details of a record, such as a user, by its ID in Cornerstone HR.
Input
Input fields dynamically generate based on the object you select. The following field is common to all objects. Refer to the Cornerstone API documentation for a complete list of input fields.
| Object | Select the object you plan to retrieve. Options are User and LO. |
Output
Output fields dynamically generate based on the object you select. Refer to the Cornerstone API documentation for a complete list of output fields.
