Cornerstone HR - Search records action
The Search records action searches for records that match your criteria in a Cornerstone HR object you select.
Input
Input fields dynamically generate based on the object you select. The following field is common to all objects. Refer to the Cornerstone API documentation for a complete list of input fields.
| Object | Select the object you plan to search. Options include User, Transcript, Session, Goal, Job requisition, Job applicant, and other Cornerstone HR objects related to training, certification, and recruiting. |
Output
Output fields dynamically generate based on the object you select. Refer to the Cornerstone API documentation for a complete list of output fields.
