Cornerstone HR - New webhook event (real-time) trigger ​
The New webhook event (real-time) trigger activates when Cornerstone HR sends a webhook notification for an event type you select, such as training completed or employee created.
Input ​
Input fieldDescription
Event typesSelect one or more event types you plan to monitor. Only matching events trigger this recipe. Options are grouped into categories, including Employee, Skills library, Training, User ratings, User skills, Status, Recruiting, Ecommerce, and Alerts.
Webhook API keyEnter the x-api-key value configured on your Cornerstone HR webhook endpoint. Cornerstone HR sends this header with every webhook callback. Leave blank if API key authentication isn't enabled.
Webhook HMAC secretThe Base64-encoded secret key configured on your Cornerstone HR webhook endpoint for HMAC-SHA256 authentication. Used to verify webhook payload integrity. Leave blank if HMAC-SHA256 isn't enabled.
Output ​
Output fieldDescription
Subscription IDThe unique identifier for the Cornerstone webhook subscription.
Session IDThe unique identifier for the webhook delivery session.
Attempt numberThe delivery attempt number for this webhook notification.
OffsetThe offset of the event record within the stream.
TimestampThe date and time the event occurred.
Correlation IDThe unique identifier used to correlate related events.
LagThe delay, in seconds, between when the event occurred and when it was delivered.
Event nameThe name of the Cornerstone event that occurred, for example, Training completed or Employee created.
DataAn object containing the event-specific details. The Data field's contents vary based on the event type received. Refer to the Cornerstone Webhooks Guide for the fields available for each event type.
