Cornerstone HR - Search records using OData query action
The Search records using OData query action returns Cornerstone HR records that match an OData query you provide.
Input
| Object | Select the object or reporting view you plan to query. For example, User. You can also provide the internal name of a custom object. |
| Query | Enter an OData filter condition to filter results. For example, user_create_dt le cast('2016-08-16', Edm.DateTimeOffset) and user_id eq 78. |
| Select fields | Select the fields to include in the response. All fields are returned if left blank. |
| Page size | Enter the maximum number of records to return. The maximum is 1000. Default is 100. |
| Offset | Enter the number of records to skip before returning results. |
Output
Output fields dynamically generate based on the object you select. Refer to the Cornerstone API documentation for a complete list of output fields.
