Cornerstone HR - Update record action
The Update record action updates a record, such as a user, in Cornerstone HR.
Input
Input fields dynamically generate based on the object you select. The following field is common to all objects. Refer to the Cornerstone API documentation for a complete list of input fields.
| Object | Select the object you plan to update. Options are User, LO, Job applicant status, Goal, and Goal progress. |
Output
Output fields dynamically generate based on the object you select. Refer to the Cornerstone API documentation for a complete list of output fields.
