Are you an LLM? You can read better optimized documentation at /en/connectors/google-workspace/action-delete-record.md for this page in Markdown format
Google Workspace - Delete record action
The Delete record action deletes an object in Google Workspace. To configure the action, you must first select the type of Object you plan to add. The recipe editor generates additional fields based on your selection.
The Delete record action supports the following Object types:
Delete a user
The Delete a user Object selection deletes a user in Google Workspace.
| Email address | Enter the user primary or alias email address you plan to delete. |
Output
| Deleted | A boolean (true or false) value indicating whether the user was successfully deleted. |
Delete a user alias
The Delete a user alias Object selection deletes an alias email address of the user in Google Workspace.
| Email address | Enter the user primary email address, alias email address, or unique user ID. |
| Alias | Enter the user alias email address. |
Output
| Deleted | A boolean (true or false) value indicating whether the user alias was successfully deleted. |
Delete a group
The Delete a group Object selection deletes a group in Google Workspace.
| Group email address | Enter the group email address you plan to delete. |
Output
| Deleted | A boolean (true or false) value indicating whether the group was successfully deleted. |
Delete an organizational unit
The Delete an organizational unit Object selection deletes an organizational unit in Google Workspace.
| Organizational unit | Enter the organizational unit you plan to delete. |
Output
| Deleted | A boolean (true or false) value indicating whether the organizational unit was successfully deleted. |
Delete a member of a group
The Delete a member of a group Object selection deletes a member of a group in Google Workspace.
| Group email address | Enter the group email address, group alias, or unique group ID. |
| Group member email address | Select the user or group email address to delete from this group. |
Output
| Deleted | A boolean (true or false) value indicating whether the group member was successfully deleted. |
Delete a role assignment
The Delete a role assignment Object action deletes a user role assignment in Google Workspace.
| Role | Select the role to be deleted in Google Workspace. |
Output
| Deleted | A boolean (true or false) value indicating whether the role assignment was successfully deleted. |
Delete app specific passwords
The Delete app specific passwords Object selection deletes the user app specific passwords in Google Workspace.
| Email address | Enter the user email address, including primary, alias, or a unique user ID. |
| Code ID | Select the app-specific password unique ID to be deleted. |
Output
| Deleted | A boolean (true or false) value indicating whether the app specific password was successfully deleted. |
Delete verification code
The Delete verification code Object selection deletes the verification code associated with a user email address in Google Workspace.
| Email address | Enter the user email address. |
Output
| Deleted | A boolean (true or false) value indicating whether the verification code was successfully deleted. |
Delete access token
The Delete access token Object selection deletes the access token issued to a client under a user.
| Client ID | Enter the client ID of the application to which the token is issued. |
Output
| Deleted | A boolean (true or false) value indicating whether the access token was successfully deleted. |
Delete license assigned to a user
The Delete license assigned to a user Object selection deletes a product license assigned to a user in Google Workspace.
| Product ID | Enter the product name for which you plan to delete the user license. |
| SKU to update | Enter the product SKU unique identifier. |
| Email ID | Enter the user email ID that's associated with the license you plan to delete. |
Output
| Deleted | A boolean (true or false) value indicating whether the license was successfully deleted. |
Delete mobile device resource assigned to a user
The Delete mobile device resource assigned to a user Object selection deletes a mobile device resource assigned to a user in Google Workspace.
| Resource ID | Enter the API service unique ID used to identify the mobile device. |
Output
| Deleted | A boolean (true or false) value indicating whether the mobile device resource was successfully deleted. |
