IDP by Workato - Classify document using IDP by Workato action
The Classify document action analyzes a document’s content and assigns it to a predefined category based on provided guidelines.
Input
| File contents | Provide the file content to classify. |
| File name | Enter the file name with its extension or specify the type in File type. |
| File type | Select the file type of the uploaded content. This overrides the inferred type from File name. Supported types include png, jpg, webp, gif, and pdf. PDF files can contain up to 50 pages with IDP model v4. Earlier versions support up to 15 pages. |
| List of categories | Create a list of categories to classify the text. |
| IDP version | Select the IDP version you plan to use. Refer to IDP model versions for more information. |
Output
| Remaining calls | Number of IDP API calls left in the current period. |
| Consumed calls | Number of IDP API calls used. |
| Reset time | Timestamp when the call limit resets. |
| Category | Assigned category based on document content. |
| Confidence scores | Confidence level of the classification. |
