Managed File Transfer ​
Workato Managed File Transfer (MFT) is a standards-based, enterprise-grade solution for secure, automated, and scalable file transfers. MFT includes built-in encryption, scheduling, monitoring, and embedded SFTP and FTP(s) servers.
Transfer orchestration ​
File transfers automate file exchanges with built-in processing, scheduling, and error handling. Refer to the following documentation for more information:
File transfers: Define where to pick up and deliver files.
Source file handling: Configure what happens to source files after a successful transfer, including archiving to a folder or deletion.
Processing actions: Configure processing steps such as file renaming, encryption and decryption with PGP, and compression and decompression.
Schedule transfers: Configure time-based schedules for file transfers using intervals or cron expressions.
Error handling and retries: Configure automatic retry behavior, including maximum retry duration and transfer auto-stop behavior.
Monitor transfer activity: View run history and per-file status.
Workato Logs: View file transfer events across all file transfers.
Triggers: React to file transfer events, such as failed or successful transfer runs, using MFTOps recipe triggers.
File servers ​
File servers provide managed SFTP and FTP(s) endpoints for secure file exchange with partners and systems. Refer to the following documentation for more information:
Workato SFTP server: Connect to encrypted file transfer endpoints at sftp.workato.com. You can create accounts, set folder permissions, and configure authentication with SSH keys or passwords.
Workato FTP(s) server: Connect to systems that require FTP-based file transfer.
Monitor server activity: Track connection attempts, authentication events, file operations, and user activity.
FEATURE AVAILABILITY
Contact your Customer Success Manager for information about access to Workato MFT.
