Microsoft Word - Update document content action ​
The Update document content action applies block-level operations, such as insert, replace, or delete by element ID, or replaces the full document content.
Input ​
Input fieldDescription
File sourceSelect where the document is stored. Options are OneDrive and SharePoint.
DocumentSelect the Word document from a folder-tree list scoped to the file source you selected.
Update modeChoose how to update. Block operations applies targeted changes by element ID. Full replace (XML) and Full replace (binary) accept raw content.
Operation typeSelect the type of block operation to perform. Options are Replace, Delete, Insert before, Insert after, Insert at start, and Insert at end. The Operation type field is only available when Update mode is Block operations.
Element IDEnter the element ID of the block to target. The Element ID field is only available when Update mode is Block operations.
Content XMLEnter the raw XML content for the block. The Content XML field is only available when Update mode is Block operations, and it's mutually exclusive with Block structure. Delete operations don't require this field.
Block structureBuild content with structured fields instead of raw XML, such as block type, text, heading level, list type, or nesting level. Provide table rows for table blocks. The Block structure field is only available when Update mode is Block operations, and it takes precedence over Content XML.
ETagOptional. Provide the ETag from a previous action. The update fails if the document was modified since you provided this value.
Output ​
The following are a representative set of output fields. Refer to the Microsoft Graph driveItem documentation for more information on available output fields.
Output fieldDescription
Document IDThe document's unique identifier.
ETagThe ID representing the document version after the update.
Last modified dateThe date and time the document was last modified.
Last modified byThe application and user that last modified the document.
File nameThe document file name, including its extension.
Created dateThe date and time the document was created.
Download URLA pre-authenticated URL you can use to download the document.
Web URLThe URL to view the document in the browser.
Parent referenceDetails about the document's parent folder, including drive type, drive ID, folder name, and path.
Size (bytes)The document size in bytes.
