Microsoft Word
Microsoft Word is a word processing application from Microsoft that's part of the Microsoft 365 suite. Workato's Microsoft Word connector enables you to integrate and automate workflows between Word documents and third-party applications.
API version
The Microsoft Word connector uses the Microsoft Graph API v1.0.
Connection setup
The Microsoft Word connector supports the following authentication types:
- Authorization code grant authentication (OAuth 2.0)
- Client credentials-based authentication (OAuth 2.0)
MICROSOFT MFA ENFORCEMENT
Authorization code grant authentication requires the following value for tenant-specific account types:
- Tenant ID
Minimum and default scopes
The Microsoft Word connector requests the following scopes for authorization code grant connections by default. These scopes are necessary to use all of the connector's triggers and actions. Additionally, you must assign these permissions to the Workato app as Delegated permissions in the Azure portal.
Files.ReadFiles.ReadWriteFiles.Read.AllFiles.ReadWrite.AllUser.Readoffline_access
The following minimum scopes are required to establish a connection to Microsoft Word using authorization code grant authentication:
Microsoft Word setup for authorization code grant authentication
Complete the following steps to set up Microsoft Word for authorization code grant authentication:
- Register the Workato app in the Azure portal
- Assign permissions to your app
- Obtain the Directory (tenant) ID from the Azure portal
View register the Workato app in the Azure portal steps
Sign in to the Azure portal.
https://www.workato.com/oauth/callbackSelect Register.
View assign permissions to your app steps
Complete the following steps to assign permissions to your app:
Go to your newly registered app and select Manage > API permissions in the navigation sidebar.
Click + Add a permission and select Microsoft Graph.
Add the required permissions. You must assign Application or Delegated permissions based on your connection type.
Add permissions
Click Add permissions. If specific permissions require admin consent, refer to Connect Microsoft Entra ID to the Microsoft Word connector to learn more.
View obtain the Directory (tenant) ID from the Azure portal steps
Complete the following steps to obtain the Directory (tenant) ID from the Azure portal:
App details
Copy and save the Directory (tenant) ID for use in Workato.
Connect to Microsoft Word with authorization code grant authentication
View connect to Microsoft Word with authorization code grant authentication steps
Complete the following steps to set up an authorization code grant connection to Microsoft Word in Workato:
Search for Microsoft Word and select it as your app.
Use the Account type drop-down menu to select the type of account you plan to use. The available choices are Common and Tenant specific.
Use the Authentication type drop-down menu to select Authorization code grant.
Optional. The connector requests a set of scopes necessary for all triggers and actions to function properly by default. Go to the Advanced settings section to manually select the permissions instead. The minimum permissions required to establish a connection are User.Read and offline_access. Workato requests these permissions regardless of the permissions you select. Refer to Minimum and default scopes for more information.
Click Sign in with Microsoft.
This authentication method requires the following values:
- Tenant ID
- User ID
- Client ID
- Client secret
COMPATIBLE AUTHENTICATION
Client credentials-based authentication is only compatible with tenant-specific connections.
Microsoft Word setup for client credentials-based authentication
Complete the following steps to set up Microsoft Word for client credentials-based authentication:
- Generate a client secret
- Obtain the Application (client) ID, Object ID, and Directory (tenant) ID from the Azure portal
- Obtain the User ID from the Azure portal
Add permissions
View generate a client secret steps
Click + New client secret.
Click Add.
Copy and save the client secret value
View obtain the Application (client) ID, Object ID, and Directory (tenant) ID from the Azure portal steps
Complete the following steps to obtain the Application ID, Object ID, and Directory (tenant) ID from the Azure portal:
App details
Copy and save the Application (client) ID, Object ID, and Directory (tenant) ID for use in Workato.
View obtain the User ID from the Azure portal steps
Complete the following steps to obtain the User ID from the Azure portal:
Go to Home > Users to obtain the User ID.
Select users
Search for and select the default user you plan to use to perform operations. This user doesn't establish the connection but is required for performing certain operations that an app can't perform. It's also required in picklists to pull user data. For example, the folder picklist populates folders belonging to the default user.
Copy and save the User principal name. Use this value as the User ID in Workato.
Connect to Microsoft Word with client credentials-based authentication
View connect to Microsoft Word with client credentials-based authentication steps
Complete the following steps to set up a client credentials-based connection to Microsoft Word in Workato:
Select Tenant specific as the Account type. This option supports accounts tied to a specific organization (tenant).
Microsoft Word client credentials-based connection setup
Provide your Tenant ID. This is the Directory (tenant) ID for your app. Refer to Obtain the Application (client) ID, Object ID, and Directory (tenant) ID from the Azure portal for more information.
Use the Authentication type drop-down menu to select Client credentials.
Provide the User ID, Client ID, and Client secret for your app. Refer to Obtain the Application (client) ID, Object ID, and Directory (tenant) ID from the Azure portal and Generate a client secret for more information.
View connect Microsoft Entra ID to the Microsoft Word connector steps
To connect to the Microsoft Word connector using a Microsoft Entra ID account, ensure that all the consent requests are granted by admins.
Complete the following steps to grant admin consent using an admin account:
Sign in to your Azure portal and navigate to Enterprise Applications > Activity > Admin consent requests.
Approve the necessary consent requests.
Microsoft Word common connection setup
Microsoft Word tenant specific connection setup
