NetSuite REST - Get async job result action
The Get async job result action retrieves the status and result of an asynchronous job in NetSuite REST.
Use this action to check the progress and outcome of jobs created by the Create records (async), Update records (async), Upsert records (async), or Delete records (async) batch actions.
Input
| Async job ID | Enter the identifier of the asynchronous job to retrieve. Use the Async job ID returned by an async create, update, upsert, or delete action. |
Output
| Started at | The timestamp when the job started processing. |
| Completed at | The timestamp when the job completed. |
| Progress | The current progress of the job. |
| Task results | A list containing one entry per record submitted in the batch. Each entry reports the outcome for a single record. |
