NetSuite REST - Initialize record action
The Initialize record action retrieves a pre-filled record without creating it in NetSuite REST.
The action populates a target record with data from an existing reference record and returns it without saving it in NetSuite, so you can inspect or modify the values before you create the record.
Use the Transform record action to create a record from an existing source instead of filling and retrieving it.
The Record and Reference record types must form a supported transformation pair. Refer to the Supported transformation types for valid source-to-target combinations. For setup requirements, see REST Web Services prerequisites and setup.
Input
Input fieldDescription
RecordSelect the NetSuite record type to initialize. The action returns a pre-filled record of this type.
Reference recordSelect the NetSuite record type of the existing reference record. The action uses data from this record to pre-fill the target record.
Reference record IDEnter the internal ID of the existing reference record instance.
Output
The output is the pre-filled target record. The output schema reflects the record type you select in the Record field, including its standard fields and any custom fields configured in NetSuite. The available output fields vary by record type because the schema is dynamic. After you select a record type, the recipe editor displays the output fields for that record.
