NetSuite REST - Search custom records action
The Search custom records action allows you to search for custom records in NetSuite REST. You can either enter a Search query or use the Search settings input fields to filter records. Workato prioritizes the Search query field if you specify both.
You can only use fields with known data types to filter the input fields. Use a custom Search query to filter by other fields.
PREREQUISITES
You must complete the following before you use this action:
- Enable the SuiteAnalytics Workbook feature on your account.
- Have the SuiteAnalytics Workbook (View) permission on your role.
Refer to the NetSuite Prerequisites and Setup for REST Web Services guide for more information about the features and permissions required for REST Web Services.
Input
| Custom record | Select a NetSuite custom record type, or toggle to enter a custom value. The list populates from the custom record types located in your account at Customization > Records > Record Types. |
| Search query | Provide a search query to filter records, such as name START_WITH test. Refer to the NetSuite Records Catalog for more information on field names, types, and availability. |
| Search settings | Expand this section to configure search settings. |
| String fields | Select the search operator for all String fields. Default is CONTAIN. |
| Number fields | Select the search operator for all Integer, Number, Float, Double, and Duration fields. Default is EQUAL. |
| Date/Time fields | Select the search operator for all Date, Time, and DateTime fields. Default is ON. |
| Limit | Specify the number of records to retrieve on a single page. The maximum is 1000. The default is 200. |
| Offset | Specify the starting position for retrieving records. The default is 0. |
Output
| Items | A list of records returned as a result of the search. Each item's fields depend on the Custom record type you select. |
| Has more | Indicates whether there are more records associated with the search query that weren't included in the output. |
| Count | The number of records returned in the current response. |
| Offset | The starting index of the records in the current response relative to the full result set. |
| Total results | The total number of results matching the search criteria. |
