Odoo (JSON-2) - New/updated object trigger
The New/updated object trigger runs when a record of the selected object is created or updated in Odoo (JSON-2). Each poll returns up to 100 new or updated records, ordered by their last-modified date.
Input
| Object type | Select the object you plan to monitor, such as Contact or Sales order. The list of objects is populated dynamically from your environment. |
| Trigger poll interval | Select the frequency at which trigger checks for new events, from the drop-down menu. Defaults to minutes if left blank. The minimum value allowed is 5 minutes. Refer to Polling intervals for more information. |
Output
Output fields are dynamically generated based on the object you select. Refer to the Odoo documentation for a complete list of output fields.
