SAP - Send IDoc action (Legacy)
Action Send IDoc
This action allows you to send IDoc to an on-premise SAP system, or to an SAP system on a server behind the corporate firewall. You must configure IDocs in your SAP system before using this action.
LEGACY ACTION
This action is a legacy version that is retained for backward compatibility. We recommend that you use the Send IDoc (Advanced) action instead. The Advanced action removes the need for dummy configurations that were previously required for this action.
Input
Field nameDescription
IDoc nameThe IDoc to send. You can select an IDoc name from the picklist or enter IDoc name directly. The picklist only displays IDocs that are configured in the partner profile in your SAP system.
Wait for SAP to process the IDoc?IDoc is processed asynchronously in SAP. So you can configure the recipe to wait for the processing to finish before moving on to the next recipe step.
Check IDoc status everyThis field will appear if Wait for SAP to process the IDoc is set to Yes. Select how often Workato should call SAP. This is useful when you want to control the workload of your SAP system.
ERROR BEHAVIOR
The Send IDoc action confirms that SAP accepted the IDoc at a technical level. A successful step doesn't indicate that SAP completed business processing. Business failures may surface later through IDoc status tracking rather than as step-level errors. Refer to Error behavior in the SAP RFC connector for details.
After IDoc is selected, you can select IDoc input segments and fields. In this example, E1MARAM and EDI_DC40 are selected.
IDoc input segment 1
IDoc input segment 2
Default IDoc parameters
Workato provides the following default values for EDI_DC40 segments. Beginning with OPA version 22.2, providing values for the following attributes in EDI_DC40 segments overrides the default values. Other fields in the EDI_DC40 segment are empty by default.
Field NameDescriptionOPA V22.1 and priorOPA V22.2 and aboveDefault value
SNDPRTPartner type of senderCannot be overriddenCan be overriddenLS indicates Logical System.
SNDPORSender portCannot be overriddenCan be overriddenThe ALE port definition based on the current connection.
SNDPRNPartner number of senderCannot be overriddenCan be overriddenThe partner number defined in the distribution model based on the current connection.
RCVPRTPartner type of receiverCannot be overriddenCan be overriddenLS indicates Logical System.
RCVPORReceiver portCannot be overriddenCannot be overriddenSAP plus systemName. System name is determined by the current connection to the SAP server: host/user/password, and prefixed with SAP. For example, if the systemName is XYZ, the ReceiverPort is SAPXYZ.
RCVPRNPartner number of receiverCannot be overriddenCan be overriddenThe SAP server's partner number.
ARCKEYKey for external message archiveCan be overriddenCan be overriddenUnique submission ID which enables Workato to track IDoc status. If overridden, checking for IDoc status in the "Send IDoc" action and "Check IDoc Status" actions will not work. We recommend that you leave this field blank.
MANDTClientCan be overriddenCan be overriddenThe value of the user_logon.client provided in the current connection.
DIRECTDirection of communicationCan be overriddenCan be overridden1 indicates Outbound communication. We recommend that you leave this field blank.
OUTMODOutput modeCan be overriddenCan be overridden2 indicates the output mode in the sender application.
MESTYPMessage typeCan be overriddenCan be overriddenThe selected IDoc message type based on the IDoc you select. For example, if you select the IDoc ORDERS.ORDERS05.ZORDERS, the message type is ORDERS.
IDOCTYPBasic IDoc typeCan be overriddenCan be overriddenThe selected IDoc basic type based on the IDoc you select. For example, if you select the IDoc ORDERS.ORDERS05.ZORDERS, the basic type is ORDERS05.
CIMTYPExtension typeCan be overriddenCan be overriddenThe selected IDoc basic type based on the IDoc you select. For example, if you select the IDoc ORDERS.ORDERS05.ZORDERS, the extension type is ZORDERS. If no extension is selected, then this field is empty.
Output
IDoc numberSAP assigns this IDoc number after receiving the IDoc.
StatusStatus of the IDoc after being received by SAP.
Status codeStatus code of the IDoc after being received by SAP.
Status descriptionStatus description of the IDoc after being received by SAP.
Submission IDWhen Workato sends an IDoc to SAP, we will attach a Submission ID to that IDoc. You can use that ID to check for IDoc status using action Check IDoc Status.
DetailLong text of the IDoc after being received by SAP. (OPA v27 and above required to populate value for this field)
