TRADACOMS EDI - Look up TRADACOMS code value action
The Look up TRADACOMS code value action translates a standard Article Numbering Association (ANA) code, for example a transaction code, VAT category, or priority, into its meaning in TRADACOMS EDI.
Input
| Code list | Select the ANA code list to use, or enter an element code, for example TCDE or VATC. |
| Code | Enter the code value to look up, for example 0430 or S. The action keeps leading zeros on numeric codes, so enter 0430 instead of 430. |
Output
| Code | The matched code. Returns the code you entered if the action finds no match. |
| Found | A boolean value (true or false) that indicates whether the action found the code in the selected code list. |
| Meaning | The code's meaning, for example New orders. Empty if the action finds no match. |
| List name | The selected code list's full name, for example VAT rate category code (ANA List 12). |
| Entries | Every code in the selected code list. |
| Code (Entries) | The entry's code. |
| Meaning (Entries) | The entry's meaning. |
