TRADACOMS EDI - Generate TRADACOMS file (typed) action ​
The Generate TRADACOMS file (typed) action generates a TRADACOMS transmission file from named fields in TRADACOMS EDI. Select a File type to display named fields for the header, detail, VAT, and trailer messages. The action automatically generates the envelope, assigns message numbers, and calculates all counts.
Input ​
Input fields dynamically generate based on the File type you select. Refer to the recipe editor to view the fields available for your selected file type.
Input fieldDescription
File typeSelect the file type, for example Order File or Invoice File. The selected file type determines which typed input fields appear. Select Other / custom to provide custom schemas or use raw segments for message types without a schema.
Custom message schemas (JSON)Optional. Enter JSON keyed by message type to add or override field mappings, for example {"ORDERS": {"properties": {"my_field": {"path": "CLO/1", "picture": "X(40)"}}}}. The action uses the built-in schemas for the selected file type if you leave this field blank.
Sender codeEnter the sender's location code (STX FROM), such as an EAN/GLN. For example, 5000000000001.
Recipient codeEnter the recipient's location code (STX UNTO), such as an EAN/GLN. For example, 5000000000002.
Sender referenceEnter a unique transmission reference (STX SNRF).
File header messageEnter the header message's fields.
Detail messagesEnter one entry per document, for example an order, invoice, or bill.
VAT trailer messagesOptional. Enter VAT trailer details. The VAT trailer messages field is only available for file types that include a VAT trailer message, for example Invoice File. The action omits the VAT trailer message from the file if you leave this field blank.
File trailer messageOptional. Enter the trailer message's fields. The action omits the trailer message from the file if you leave this field blank.
Segment separatorOptional. Select the layout between segments in the output document. Options are Newline or None. Defaults to Newline if left blank.
Output ​
Output fieldDescription
DocumentThe generated TRADACOMS file.
Segment countThe total number of segments in the file.
Message countThe total number of messages in the file.
