Veeva Vault - Bulk upsert records (batch) action
The Bulk upsert records (batch) action posts up to 500 records in a single request to the Vault bulk endpoint in Veeva Vault.
Input
| Object | Select the Vault object you plan to upsert. For example, Product. This list is populated dynamically from your Vault. |
| Match field | Select the unique field used to match existing records. Defaults to External ID. This list is populated dynamically from the selected object's unique fields. |
| Migration mode | Set to enable record migration mode. Requires the Record Migration permission in Vault. Defaults to unchecked. |
| Records | List of records to upsert. Maximum 500 per batch. |
Output
| Response status | The overall status of the bulk write operation. |
| Success count | The number of records successfully written. |
| Warning count | The number of records evaluated but not changed, for example an upsert no-op. |
| Failure count | The number of records that failed to write. |
| Data | An array with one entry per record in the batch: Response status, ID, URL, Event, ID param value, Errors, and Warnings. |
