Veeva Vault - Bulk delete records (batch) action
The Bulk delete records (batch) action deletes up to 500 records by ID in a single request in Veeva Vault.
Input
Input fields are generated dynamically based on the object you select. Refer to the Veeva Vault documentation for a complete list of input fields. The following field is common to all objects.
| Object | Select the Vault object you plan to delete. For example, Product. This list is populated dynamically from your Vault. |
Output
| Response status | The overall status of the bulk delete operation. |
| Success count | The number of records successfully deleted. |
| Warning count | The number of records evaluated but not changed. |
| Failure count | The number of records that failed to delete. |
| Data | An array with one entry per record in the batch: Response status, ID, Errors (array of Type and Message), and Warnings (array of Warning type and Message). |
