Veeva Vault - Create document relationship action
The Create document relationship action creates a relationship on a source document version, linking it to a target document, in Veeva Vault.
Input
| Source document type | Select the source document type. This list is populated dynamically from your Vault. Select this first, since it determines the available Relationship type options. |
| Relationship type | Select the relationship type. Options depend on the Source document type you select. This list is populated dynamically from your Vault. Standard system types, such as Based On, might not be creatable through the API. |
| Source document ID | Enter the internal Vault document ID of the source document, for example 776. |
| Source major version | Enter the major version of the source document, for example 0. |
| Source minor version | Enter the minor version of the source document, for example 1. |
| Target document ID | Enter the internal Vault document ID of the target document. |
| Target major version | Optional. Enter the major version of the target document. Required for target version-specific relationship types. |
| Target minor version | Optional. Enter the minor version of the target document. Required for target version-specific relationship types. |
Output
| Response status | The status of the relationship creation operation. |
| Response message | A message describing the result of the operation. |
| Relationship ID | The ID of the created relationship. If the relationship already exists, Vault returns 0, which is expected and not a failure. |
