Veeva Vault - Create document version action
The Create document version action adds a new draft version of an existing document in Veeva Vault. You can either copy the current source file or upload a new one as the draft.
Input
| Document ID | Enter the internal Vault document ID, for example 776. |
| Create draft | Select how to create the new draft. Copy from current version copies the current source file without uploading. Upload new file uploads a new source file as the draft. |
| Version description | Optional. Enter a version description shown in Version History. Maximum 1,500 characters. |
| Suppress rendition | Optional. Select to skip automatic viewable rendition generation for the uploaded file. Only available when Create draft is Upload new file. |
| File content | Enter the binary content of the new document source file. Accepts a file or stream reference. For example, mapped from another action's output or a base64-encoded string. Required when Create draft is Upload new file. |
| Content type | Optional. Enter the MIME type of the file, for example application/pdf. Defaults to application/octet-stream if left blank. Only available when Create draft is Upload new file. |
| File name | Enter the file name, including the extension, for example brochure.pdf. Required when Create draft is Upload new file. |
Output
| Response status | The status of the version creation operation. |
| Response message | A message describing the result of the operation. |
| Major version | The major version number of the new draft. |
| Minor version | The minor version number of the new draft. |
