Veeva Vault - Get record action
The Get record action retrieves the full metadata for a single Vault object record by its ID in Veeva Vault.
Input
| Object | Select the Vault object. For example, Product. This list is populated dynamically from your Vault. |
| Record ID | The Vault record ID. For example 00P000000000301. |
Output
Output fields are dynamically generated based on the object you select. Refer to the Veeva Vault documentation for more information.
