Veeva Vault - Search records action
The Search records action searches records, such as products, in Veeva Vault. The action uses a Vault Query Language (VQL) query to run the search.
Input
| Object | Select the Vault object. For example, Product. This list is populated dynamically from your Vault. |
| Fields to retrieve | Select one or more fields to include in the VQL SELECT. Defaults to id, name__v when left blank. |
| WHERE clause | Enter a VQL WHERE clause, without the WHERE keyword. |
| ORDER BY clause | Enter a VQL ORDER BY clause, without the ORDER BY keyword. |
| Page size | Number of records per page. Defaults to 200, with a maximum of 1000. |
| Page token | To fetch the next or previous page, map the Next page token or Previous page token from a prior call. All other inputs are ignored when provided. |
Output
| Total records | The total number of records matching the query. |
| Records on this page | The number of records returned on this page. |
| Page size | The page size used for this query. |
| Next page token | Map this into Page token on a subsequent call to fetch the next page. |
| Previous page token | Map this into Page token on a subsequent call to fetch the previous page. |
| Records | An array of records for the selected object. Output fields are dynamically generated based on the object you select. Refer to the Veeva Vault documentation for more information. |
