Veeva Vault - Search audit trail action
The Search audit trail action retrieves audit history records for documents, objects, system events, domain events, or login events in Veeva Vault.
Input
| Audit trail type | Select the audit trail you plan to query. |
| Start date | Enter the start of the date window. Defaults to the start of the previous day. The window can't exceed 30 days. |
| End date | Enter the end of the date window. Defaults to now. The window can't exceed 30 days from the Start date. |
| Events filter | Enter a comma-separated list of event types to return. Only shown for Document audit trail and Object audit trail. |
| Objects filter | Enter a comma-separated list of object API names you plan to filter by. Only shown for Object audit trail. |
| Limit | Enter the number of audit records per page. Defaults to 200, maximum 1000. |
| Offset | Enter the number of records to skip. Defaults to 0. |
Output
| Total | The total number of audit records matching the query. |
| Size | The number of audit records returned. |
| Offset | The offset used for this query. |
| Limit | The quota used for this query. |
| Next page | The URL to fetch the next page of results, if any. |
| Previous page | The URL to fetch the previous page of results, if any. |
| Data | An array of audit records. Fields vary based on the selected Audit trail type. Refer to the Veeva Vault documentation for more information. |
