Veeva Vault - Run VQL query action
The Run VQL query action submits a raw Vault Query Language (VQL) query against documents, objects, or system tables in Veeva Vault.
Input
| VQL query | Enter the VQL query to run. |
| Include query describe metadata | Select Yes or No to set the X-VaultAPI-DescribeQuery: true header on the request. Defaults to No. |
| Record properties | Select All, Hidden, Redacted, or Weblink to indicate how to apply the X-VaultAPI-RecordProperties header. Omit to skip the header. |
| Record schema | Optional. Enter the schema for the records returned by the query. Define fields to expose them as typed datapills downstream. Leave blank to return the records as raw JSON objects. |
Output
| Total | The total number of records matching the query. |
| Size | The number of records returned. |
| Page size | The page size used for this query. |
| Page offset | The page offset used for this query. |
| Next page | The URL to fetch the next page of results, if any. |
| Previous page | The URL to fetch the previous page of results, if any. |
| Records | An array of records. If you defined a Record schema, each record has the fields you defined. Otherwise, each record is returned as raw JSON. |
