Workato EDI - Convert data format action
Use the Convert data format action to convert JSON data into X12 format or X12 data into JSON format.
Input
| Data | Map in a datapill containing JSON or X12 data. For example, you can obtain a Transaction message from the output of a Get record (Transaction message) action. |
| Input data format | Specify the format of your source data. Available options are JSON and EDI-X12. |
Output
| EDI-X12 data or JSON data | The converted data. The data is in X12 or JSON format depending on the option selected. |
